How do i prevent infill with curaengine 1.0.6
Im trying to print flexible bracelets using files taken from thingiverse with curaengine 1.0.6 but for some reason, cura will not let me print without infill. Consequently my bracelets all have printed infill structure over the whole of the bracelet.
How can i stop this? In the cura configuration form i have unchecked the top and bottom infill boxes and set the other thickness parameters to zero but still it prints with infill!! I cannot find a way to completely remove all infill so cannot get a flexible finished object. Can anyone help?
In the slicer tab there is a slider “Infill Density”
Slide it to the left until it says “0”
Thanks. Just seen it now. I didnt see the scroll bar on that tab.
It depends how its been modeled. If you have a link it might help to understand.
In CuraEngine
If the volume that is being filled (unwanted) is an enclosed void…
Then you need to change the “Support Type:” to None or Touching bed,
the other parameters for infill will only affect how dense the solid part will be
