Hi all,
I am planning to control the IKEA RGB-LEDs.
I set up the RPI with a 4x relay ( I am not good in electronic parts, so I took the decent ones)
I can control the GPIO (by wiringPi) and switch the relays. That works perfectly.
I added some GPIO instructions to the SETTINGS menu, to see if everything is ok, with the wiring
Question is:
How can I set a GPIO pin to high if the heat bed is on temperature?
How can I set a pin, if the printer is printing… or anything else possible
I am missing the following information:
- How can I react on a defined GCODE received by onto print
- or if the tis not possible, how can I generate (develop) a new event hook (Eventhandler) like the PRINT_FINISHED or similar events
So the chain is something like:
- printer reports a certain info (TEMP-REACHED, what ever) to the octoprint
- octoprint doing an action (setting GPIOpin on RPI) depending of the GCODE or event or action
- I am happy!!!
I went thru the doc and the source code but did not get the right sport for an entry.
If one could give me a hint, would be appreciated.
Frank
