When slicing with ‘Curaengine’, when the print begins the hotend doesn’t go down to the bed. However, when slicing with ‘Slic3r’ it works perfectly fine.
I can’t see any settings which could be causing this as when printing objects previously it has worked fine. I thought it may have been the file so downloaded a different file and it still didnt work.
What could be causing this?
[quote=“LMB20”]When slicing with ‘Curaengine’, when the print begins the hotend doesn’t go down to the bed. However, when slicing with ‘Slic3r’ it works perfectly fine.
What could be causing this?[/quote]
Post your curaengine start g-code please.
; Default start code
G28 ; Home extruder
G1 Z15 F{Z_TRAVEL_SPEED}
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
{IF_BED}M190 S{BED}
; Activate all used extruder
{IF_EXT0}M104 T0 S{TEMP0}
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
{IF_EXT0}M109 T0 S{TEMP0}
[quote=“LMB20”]; Default start code
G28 ; Home extruder
M107 ; Turn off fan
{IF_BED}M190 S{BED}
{IF_EXT0}M109 T0 S{TEMP0}[/quote]
Put these 2 Lines at the end of your start g-code :
G28 X0 Y0 F{Z_TRAVEL_SPEED}; home x,y
G28 Z0; home z
