Homemade designer ring :-)
I dont think it is possible to get at better result with the K8200. I am happy with the result.
The ring is very small.
Nice indeed.
Would you mind to share your Slic3r parameters?
Very nice
As Raby, slic3r parameters is it possible ?
If you can share slic3r config it will be nice
The Slice3r parameters is the K8200 standard parameteres, but the layers is changed to 0.2mm.
The key to the good result is to adjust the Speed Multiply in manuel control.
Feed rate: 50%
Flow rate: Well you have to try for yourself, but a 5% change can make a big difference. I normally have to reduce the flow rate to get optimal results.
Last there is a BIG difference in PLA. I have a black PLA but cant get any good results with it.
