Home Z axis problem
When pressing Home Z axis button the Z carriage moves towards the micro switch as it should do, but when I press the micro switch the carriage stops and and then reverses for approx. 2mm. Is something not wired correctly ?
no, that’s quite allright. After reversing, the carriage should move down again at a lower speed and stop when the switch is triggered a second time. Most RepRap electronics have this feature in order to combine high speed (first approach) and high accuracy (second approach after reversal) when homing.
Cheers,
kuraasu
Thank you Kuraasu for your prompt reply.
Mac
