I have a new HPS140i pocket oscilloscope and HPG1pocket generator.
The HPS140 is firmware version 1313. Is that the latest? And if not, how do I upgrade the firmware. I do this with a download and USB key for my larger oscilloscopes.
I would like a real charger. I cannot find anyplace in North America that sells the PSS0919. The supply is 9 Volts regulated at one-half amp minimum and barrel connector with outside negative and inner pin positive. What are the dimensions of the barrel connector should I wish to go to a nearby parts store.
When I first turned on the unit, the display would not change or clear unless I turned off the unit. Now, after turning the unit on and off about a half a dozen times it seems to work OK. Should I be concerned?
If I hook up my 10x probe (included in the 140i package) to the HPG 1, or to a B&K 4054 both at 1 KHz Square Wave, or to the back of the HPS140, I get slightly different answers on probe compensation. I am happiest to use my B&K as standard. What do you suggest as standard? My other scopes have their own verifiable compensation outlets.
My HPG1 is firmware version 1134. What is the latest for it?
Thank you for your assistance.
