Help whats wrong?
Can somebody tell me why my Printing looks like this?
http://gyazo.com/f06fe122ab5e7a7394d730123cb5ccc1
it should be this here: http://www.thingiverse.com/thing:491383
my printersettings are 200°C with PLA
i hope someboday could help me
Greetings from switzerland Recoon
Are you using clear PLA?
Could you explain what happened exactly (the infill seems messy and there is a blob somewhere).
Did it stop printing after this? If that’s the case you didn’t wait enough time before removing the SD card from your computer and the file is lacking a part of the job.
[quote=“raby”]Are you using clear PLA?
Did it stop printing after this? If that’s the case you didn’t wait enough time before removing the SD card from your computer and the file is lacking a part of the job.[/quote]
yes its clear PLA… i know its kinda bad to start but i realy wanted this kinda PLA.
The messy infill i cant explain why its here… the blobs come from pausing the program. so it stayed there for about 10 sec or so then i started it again so i can make a picture of the whole item i was printing…
my qestion why is there no material in the left back edge and the mess in the whole surface. what should i change to get it better?
im printing with the cable pluged in the computer so no SD Card used…
It’s a bit hard to tell from the picture but there could be a layer shift explaining the gap on the back and the messy infill as the layers are not on top of each other.
If its indeed the case you’ll have to check your X/Y axis alignment.
