i have just bought the vm110 USB experiment interface board. i want to use it to record two analog signals to a text file.
i was shocked to discover that there is no simple program that will let you do this on the CD. do they expect us to learn a programing language and write the program our selves? thats mad!
can any of you guys point me to a program that will record data to a text file. i just need to measure two (0-5V) signals and record a value every second.
You may try VBA (Visual Basic for Applications) programming.
See some example codes in thread:
[forum.vellemanprojects.eu/t/k8055-programming-with-visual-basic-for-applications/311/1)
Using VBA you may very easily get the values to Excel sheet.
This is to put the values in excel with VBA. How do I put the values from the analog inputs in a label in VB, without use of any other application? And how do I store the value with a timer? I’d like to see a the voltage change, every minute or so.
Hi Matthew,
Maybe you are in luck. I was working on some code for the extended USB interface board when I saw your message. I have knocked up an executable in Visual Basic for the K8055 (VM110) that I think will meet your needs. It displays the voltages of both analog inputs and records them in a text file at the same time. I can email you a zipped version of the program for you to install, if you want the code (VB2008), let me know.
[quote=“spadoosh”]Hi Matthew,
George[/img][/quote]
I’d also like to have that file if its ok with you? I’ve been looking for a way to measure the voltage of the analog inputs for a while now.
