I’ve been experimenting with support the last few days and learned allot about it. I already had some satisfying results so far. But now I wanted to step it up and try to print the statue of liberty:
I don’t really find a setting that looks ok. The problem is that the book and torch has to be supported, the rest would come out ok I think. When I find a good setting for those 2, the head gets supported too and I think that’s not really necessary. Any pointers would be appreciated.
Edit: I checked cura, the support generated there looks more promising, but I only printed once with cura, so for now I would like to stick with Slic3er
Wait 5 hours … I’m printing the same thing
Without supports: big problems like you say.
Lots of supports are generated now. I hope the statue will look good when supports are removed.
