Help/instruction for applying the analog/digital inputs
hi, dear web master;
the following is a small section of the coding of my application for using/controlling the outputs of the interface card:-
case this.value=1.00
declare outputanalogchannel in k8061.dll integer cardaddress, integer channel, integer data
outputanalogchannel(0, 1, 140)
messagebox("…",64,50,"…")
outputanalogchannel(0, 1, 0)
messagebox("…",64,4000,"…")
many output functions of the card/s can be control in this way. but i do not know how to code the analog/digital inputs. can you show me some examples. say, if there is an open-collector-output signal inputting to card no. 0, channel01, then a certain message is to be displayed for n seconds.
