Help identifying an old kit (anti-pop / plop circuit)
Quite a few years back, I built a Velleman kit that provides a delay and protection against “pop” or “plop” from a home audio amp. It has been working great. However, when I built it, I used the same type of connectors for input and output. Now, after my system has been moved, I can’t tell which is which.
So, I opened the case, hoping the PCB was marked…it is, but isn’t clear enough which leads are which. Here’s a photo:
http://www.dropfiles.net//files/1227/velleman_kit.jpg
One connector uses the blue and white (and shared black) leads. The other uses the red and yellow (and shared black) leads. Which side is input or output?
Thanks!
You can download the manual of the K4700 kit here:http://www.velleman.be/downloads/0/illustrated/illustrated_assembly_manual_k4700_rev1.pdf
Perfect. Thanks very much, VEL417.
By the way, I think this kit is at least 10 years old, and has worked perfectly since new.
