Hello
my printer does not feed filament to the print head
has anyone had such a problem before?
does anyone know how to enter filament?
thanks in advance
I think you must give us a much more detailed description what exactly is wrong before we can help you.
Is the problem that you cant get the filament through the feeder or is it something else ?
filament goes through the hole (I do it by hand)
but the engine does not feed it to the printheads
Do you feed the filament through the feeder so you can see 10-15 mm up in the tube ? You can not just put it inside the hole, youmust help it through so you see it above the feeder.
Does the extruder motor turn ?
If not start by checking rhe wiring to the motor. If it seems ok exchange the motor to the X or Y motors and try again.
When you use the “Load filament” procedure on the LCD, does the print head warm up?
