When I do an ‘auto calibration’ it works but when I print the print head is too high.
And when I check the ‘calibrate X,Y,Z’ I can’t go down to 0.0, it blocks at 1.5 every time.
Do you have a solution ?
Hello @hightdjo,
Check the endstop height (it must be 0,5mm).
Further check also the Calibration troubleshooting guide.
Vellman Support
Hi Hightdjo,
Look here:
https://forumtest.whadda.com/t/printing-only-on-the-rightside-of-the-printbed/35013/15
I did the same with the bed, only i let 3 screws away, so 3 screws and 3 springs to level the bed. Works fine.
draw a circel of 199mm and 0,5 mm thick and print that and mesure the thicknis all around to get it leveled right.
Kind regards,
Tom
