Heatsink holes
K8077 .i’m nearly at mounting the heatsink to the box, but i found out i hadn’t enough black screws (only 4 instead of 10) to put it on. So i went to the shop and bought some ofthem but it seems to be that they are a little bit more width (like 1 or 1.5 mm) than the normal ones. Now i choose to put the 4 i have left (mentioned earlier) in the bass reflex tube, to mount it, and the new ones iw ant to use to mount the heatsink. Now the question(s) are: Does it matter if i drill the heatsink 1 mm more width? And is it a good use to use the 4 black screws on the bass reflex tube?
Sorry for bad english
Should not be a problem if it is done properly.
