Heating fail melding give my K8600 3D printer
Hello @Heesemans !
Trying to understand your issue …
Is this a newly built Vertex Nano or did the “Heating” have recently stopped working ?
Have you try “control printer” then “preheat” via the LCD screen menu ( did the target temperature change or do you have any error on the LCD screen ) ?
see : https://manuals.whadda.com/article.php?id=532
Or is this somthing else ?
Hoping to help
Have a good day !
My printer have y bult en it was the first time to load PLA but heating fall. The led haven’t burn.
Sorry i don’t get it clearly … i im french …
So this is the first time you’r using it ?
Have you read all the Using the printer manual ?
Using the printer - Whadda - Manual Platform - Category
Do you see on the LCD the “temperature” and the “target temperature” what are the values when doing a filament change ?
Or may be the filament got stuck …
If you are using Cura as slicer you may have the same issue as in this topic :
https://forumtest.whadda.com/t/probleem-bij-eerste-gebruikname/32443/22
Hoping this help !
Have a good day !
Thanks, Y go and tray.
Sorry, I assumed that you have the almost built version K8600 …
If you have the VM8600 : check the temperature sensor and the heater element and their cables / connections to the main board.
Hoping you will solve the issue and get some good printing !
Have a good day!
Sorry, i am don’t asked it. Stop it.
Yes, the heating don’t work. The led don’t give ligt. Y have build the printer. When y build the printer was the fan blokking en the led never burn. By replace the kop he didn’t work en fan hy don’t work.
I’m not sure I understand (via screen menu or from printing via SD card?)
Take the time to explain the problem with photos to remove any doubt
and if possible by using a translator (to English then this result to your language and again to English to check the “stability” of the translation of the vocabulary …)
