Heated Bed Temp 763C
Hi
I get an error due to my heated bed temp registering 763 deg C. Where is the best place to start?
Hi
Thanks for the reply.
It appears not only are you quicker to answer than i expected, but you are also entirely correct. It appears I have indeed wired the heatbed sensor and the y axis micro switch to one another’s rightful place. When i press the y micro switch the heatbed reading disappears and when manually controlling the y axis motor wih the sensor unplugged the bed will move away from the switch but not toward it. Now I’m looking forward to the repair when I get some spare heat shrink tubing.
Thanks for being a genius, it’s nice.
Gav
