I used this circuit to add a 24V PSU to heated bed
k8200-wiki.de/Datei:Heizbett-Treiber.jpeg
(I don’t speak german so am using google translate)
I added a decent heatsink to the FET
The bed heats up much quicker now and I get it to 100 degrees finally.
However The LED is on when the bed is off and vice versa
(seems counter intuitive - I have checked LED polarisation and it is correct)
Is this how this should work ?
The resistor (R3) which is in series with the LED has heated up an burnt
I tried a higher wattage one also but that looks like its going the same way (based on smell).
This is obviously dangerous
I suppose I could just remove the LED and resistor as they play no functionally role other than to indicate bed status
Anybody throw any light on this ?
tks
Noel
