I try to add an heatbed to my k8400 and I would keep the glass.
My problem is cork + heatbed + glass is to large.
I try to turn the bolt Z stage to maximum (right or left) but it is again to large.
somebody have a idea ?
Hey,
I think you mean THIS
or you can check THIS
Or you can pick the original 3D part and change it.
Sorry I’m at work right now and I can´t spend too much time here. But I think you got the idea.
Regards
Jorge Manuel Oliveira
I made a slotted hole for the Z-endstop to adjust it lower.
[quote=“svdv”]I made a slotted hole for the Z-endstop to adjust it lower.
[/quote]
Wy not to change this aluminum plate with solid one + silicon heater. The simplest solution in my opinion.
Juat add a cardoard part on top of the vertical stop end
Easy and fast solution
Or you can print 3 replacement parts to lower the bed assembly closer to the aluminum support:
https://www.thingiverse.com/thing:2243656
I made Z-axis slots like svdv suggested but these will restore the maximum build height.
