I have recently purchased this K8062 interface kit, and have the following symptoms when attempting to use:
- When connected to the PC, the interface powers up correctly, with the Power LED illuminated and the DMX light off.
- When I load the supplied DMX control software (which doesnt seem to be very good at supporting any lights), the DMX light flashes continuously, and does not “go steady” at any point. I experience the same symptom when I load “FreeStyler” software.
When I exit said software, the DMX light then goes steady, and stays on, but starts flashing again as soon as I reload the software. None of the fixtures respond to any DMX commands sent via the interface regardless of software used - When running in standalone “test” mode, none of the fixtures respond.
- The fixtures all work fine off my Stairville DMX lighting desk controller, and also when using our Zero88 Fat Frog lighting desk.
The fixtures I’m using are : Stairville MH-250’s, Robe Colorspot 250XT’s, and a Robe Colorspot 575XT. I’ve also tried using it with a Mojo Spinmaster and standard Par 64 Par Cans. Can you please advise what may be the problem? As I’ve said, the PC detects and recognises the interface as a USB Human Interface Device, but nothing appears to work on the DMX side of the equation. All the wiring seems correct (both myself and a colleague have checked the wiring) and there appear to be no problems with the solder joints, however any help you can give would be most appreciated.
