Hairy top of the cube
The results after 10 minutes printing is strange, look at the picture below.
A little bit hairy!
Printer: Vertex K8400
Temperature 225 C
Abs: 1.75
Size object: 2 x 2 x 2 cm
Is there a explanation for this behavior?
Have you changed the settings in Cura?
Retraction 4mm
Retraction speed 110mm
[quote=“fender”]Is there a explanation for this behavior?[/quote]First thing that comes to mind : a clogged nozzle. 225° is too high for PLA.
I’am using ABS so the temperature must be right.
I’m printing ABS at 210°. The displayed temperature is seldom the real one so it can vary from printer to printer.
I will try at 210C.
