Gt2 upgrade
Hi, just updated to gt2 16 tooth belts, edited config h to 100 steps, but when i try to install the firmware on to the board it appears to upload ok says all is correct but is still moving the same on the X and Y axis, I assume it should be going further, I am only getting around half the travel i should get, I am using Arduino 1.06 marlin firmware v2 as i have a k8204 upgrade, what am i not doing or doing wromg
With Marlin V2 you have to reload the EEPROM settings.
thank you for the reply, could you explain exactly how to do that please
hi, think i’ve do it, thank you
[quote=“deafoldgit”]hi, think i’ve do it, thank you[/quote]You’re welcome:)
Does the printer work now?
Hi, yes working quite well, needs a little tweaking, but is big improvement, thank you
