I am back again with new problem linked to my earlier request to build in a sweep function for library files in the FGU link software see Download link: box.net/shared/a5ub2zlbjq
With this version of FGU.exe and FGUlink.dll the generator does not produce the right frequency.
I connect the generator with startgen command.
Send the command setgen(1, 350000, 10, 0) and startgen
Result: the generator generates a sine waveform of 340KHz and that is wrong! It is 10Khz to low!
After that send the command setgen(1,450000,10,0) and startgen
Result the generator generates a sine waveform of 460Khz and that is also wrong! Is is 10Khz to high!
After sending the same command again the frequency is OK at last!
Please test and correct software fault in FGU.exe or FGUlink.dll distributed via the faulty link box.net/shared/a5ub2zlbjq
Christian
