Hallo everybody,
I assembled a P8061-2 card for generating voltage steps via Micromanager. Now I was wondering if it is possible, with the same board, to generate sine waves.
Thanks for your help,
Giu
Hallo everybody,
Giu
[quote]Now I was wondering if it is possible, with the same board, to generate sine waves.[/quote]It is possible, but only at low frequency.
The analog outputs of the K8061 card can be updated with an interval of 2ms.
The minimum number of samples per sine period should be 20 or more to get “good enough” sine wave.
So the period of the sine wave will be 20*2ms = 40ms.
The maximum frequency generated will be 25Hz.
