Frozen printer
hi
i have an velleman k8200 fully asembled but it is just frozen in place i have al the software and followed the toturial and cheked it a copple times but when i hit someting in the manual movement section noting is happening.
he is getting power a stedy 15.46 v and it is connected the leds light up al 3 of them, what could be the problem?
p.s.
i broke the transisitor of the heated bed that shouldend matter right?
Couple of checks
Make sure the baud rate is set to 250000 (Windows)
Reset on Comment set to disabled
It isn’t transistor it’s thermistor which is directly mounted at the bed. or do you mean mosfet on controller print? Sure it matters if the adjusted temperatures aren’t reached than the printer can’t go on with the job.
What helped for me was to decrease baudrate in firmware, and make use of linux, of course :slight_smile:
