Here is some example code.
Counted pulses over 1 second interval are displayed in cells 1,1 and the average over 10 seconds is displayed in cells 1,2. [code]Option Explicit
Private Declare Function OpenDevices Lib “vm167.dll” () As Long
Private Declare Sub CloseDevices Lib “vm167.dll” ()
Private Declare Sub InOutMode Lib “vm167.dll” (ByVal CardAddress As Long, ByVal HighNibble As Long, ByVal LowNibble As Long)
Private Declare Function ReadAnalogChannel Lib “vm167.dll” (ByVal CardAddress As Long, ByVal Channel As Long) As Long
Private Declare Sub ReadAllAnalog Lib “vm167.dll” (ByVal CardAddress As Long, ByRef Buffer As Long)
Private Declare Sub OutputAllDigital Lib “vm167.dll” (ByVal CardAddress As Long, ByVal Data As Long)
Private Declare Sub ClearDigitalChannel Lib “vm167.dll” (ByVal CardAddress As Long, ByVal Channel As Long)
Private Declare Sub ClearAllDigital Lib “vm167.dll” (ByVal CardAddress As Long)
Private Declare Sub SetDigitalChannel Lib “vm167.dll” (ByVal CardAddress As Long, ByVal Channel As Long)
Private Declare Sub SetAllDigital Lib “vm167.dll” (ByVal CardAddress As Long)
Private Declare Function ReadDigitalChannel Lib “vm167.dll” (ByVal CardAddress As Long, ByVal Channel As Long) As Boolean
Private Declare Function ReadAllDigital Lib “vm167.dll” (ByVal CardAddress As Long) As Long
Private Declare Function ReadCounter Lib “vm167.dll” (ByVal CardAddress As Long) As Long
Private Declare Sub ResetCounter Lib “vm167.dll” (ByVal CardAddress As Long)
Private Declare Sub SetPWM Lib “vm167.dll” (ByVal CardAddress As Long, ByVal Channel As Long, ByVal Data As Long, ByVal Freq As Long)
Private Declare Sub OutputAllPWM Lib “vm167.dll” (ByVal CardAddress As Long, ByVal Data1 As Long, ByVal Data2 As Long)
Private Declare Function VersionDLL Lib “vm167.dll” () As Long
Private Declare Function VersionFirmware Lib “vm167.dll” (ByVal CardAddress As Long) As Long
Private Declare Function Connected Lib “vm167.dll” () As Long
Private Declare Sub ReadBackPWMOut Lib “vm167.dll” (ByVal CardAddress As Long, ByRef Buffer As Long)
Private Declare Function ReadBackInOutMode Lib “vm167.dll” (ByVal CardAddress As Long) As Long
Private Declare Function SetTimer Lib “user32” ( _
ByVal HWnd As Long, ByVal nIDEvent As Long, _
ByVal uElapse As Long, ByVal lpTimerFunc As Long) As Long
Private Declare Function KillTimer Lib “user32” ( _
ByVal HWnd As Long, ByVal nIDEvent As Long) As Long
Dim TimerID As Long
Dim TimerSeconds As Single
Dim n As Long
Dim CardAddress As Long
Dim Cards As Long
Dim OldCount As Long
Sub Button1_Click()
Cards = OpenDevices()
Select Case Cards
Case 0
ActiveSheet.Cells(1, 8) = “Card open error.”
Case 1
ActiveSheet.Cells(1, 8) = “Card 0 connected.”
CardAddress = 0
Case 2
ActiveSheet.Cells(1, 8) = “Card 1 connected.”
CardAddress = 1
Case 3
ActiveSheet.Cells(1, 8) = “Cards 0 and 1 connected.”
CardAddress = 0
Case -1
ActiveSheet.Cells(1, 8) = “Card not found.”
End Select
If Cards > 0 Then
InOutMode CardAddress, 1, 1
TimerSeconds = 1 ’ the timer interval is now 1 sec.
TimerID = SetTimer(0&, 0&, TimerSeconds * 1000&, AddressOf TimerProc)
End If
n = 0
OldCount = 0
ResetCounter CardAddress
End Sub
Sub TimerProc(ByVal HWnd As Long, ByVal uMsg As Long, ByVal nIDEvent As Long, ByVal dwTimer As Long)
On Error Resume Next
Dim Count As Long
Count = ReadCounter(CardAddress)
ActiveSheet.Cells(1, 1) = Count - OldCount
OldCount = Count
n = n + 1
If n = 10 Then
ActiveSheet.Cells(1, 2) = OldCount \ 10
n = 0
OldCount = 0
End If
End Sub
Sub Button2_Click()
KillTimer 0&, TimerID
CloseDevices
ActiveSheet.Cells(1, 8) = “Card closed”
End Sub[/code]
