You probably discovered that mounting any accessories on the printer’s frame is a bit inconvenient. It is a good idea with these square nuts slid in the frame but unfortunately if you want to add something after the printer is fully assembled – it can be very ungrateful.
Some of the areas are easy to be modified, like the vertical aluminium profiles – it requires just removing the top caps. However, some areas are very hard to access (like the Z carriage arm) – you would need to tear the printer apart to get into the groove in the aluminium profile.
I had to figure out how to hang something on the frame without disassembling the printer or drilling holes in the frame.
To download the files - visit my profile on Thingiverse (http://www.thingiverse.com/ljwinkler/designs) or use direct links below:
- bracket (http://www.thingiverse.com/download:409393)
- pin (http://www.thingiverse.com/download:409394)
More details/photos here: http://ljwinkler.blogspot.ie/2014/01/frame-clip-and-locking-pin-for-velleman.html
For latest updates/projects please subscribe to my blog: http://ljwinkler.blogspot.com/
Cheers
