Force Sensor 1N
Hi everyone!
First of all, I would like to apologize if this post is not in the right area.
Then, I would like to ask you for help with a problem I am having related to my PhD. The idea is to acquire the force measured by the material I am developing. However, I do not know precisely what kind of sensor I must use. I know that my material is producing very low force, probably below 1N. Another problem I face is that the contact area between the sensor and the material is very very small, almost like a single point, so pressure sensors do not kinda work.
Does anyone think that this sensor https://whadda.com/product/fsr-force-sensing-resistor-sensor-wpse477/ could work?
Thank you!
Hello @adiogoandre ,
You can indeed try this force sensor. that will be experimental.
We only have 1 type of it. But these exists in different sizes.
Another possible sensor you can use is a Piezo sensor.
These are also narrow (small). When pressure is applied to the piezo sensor, voltage is generated in mV - V. => the greater the force, the greater the voltage generated.
Reverse use of piezo sensor.
Best of luck with your PhD.
