Even though it’s 75% in Cura and saved/sliced on the printer it’s 100%. I go in and tune the print. Still 100%
Any clues? I am printing from SD card.
[quote]It’s basically the same. In Cura the value is included in your G-code. On the LCD you can modify it on the fly if you notice the printer is over extruding. Be aware that on the LCD it’s not an absolute value : if you set 80% in Cura and than 80% in the LCD you’ll get 80% of the 80% and perhaps too low a value.
flow and flow1 will have the same effect. The “Flow” variable modifies the value for both extruders and Flow1 the value of extruder 1.
[/quote]
found it on another post
Yep I remember writing that
