After printing about 15-20 spools of filament, my printer was suffering from various small issues. Worst was the worn out ‘ildugur’ linear bearings on the X and Y axis, each time the carriage changed direction your hear that there’s play on it. I postponed the overhauling a few months already as I don’t enjoy working on the Vertex; it’s all so dawn small!
So I went all the way:
- changed all timing belts (comparing old ones to the new ones: changing was not really needed)
- checked stepper motors: no play on the bearings
- XY bearings in the printer casing: no play
- changed the pfte tubes inside each hotend: there were signs of wear due to combined high temperature and filament pressure, also some leaking of black ‘tar’. It’s early to say be it appears I could print faster without filament jams after the replacement.
- changed all four ‘ildugur’ bearings: there was quite a lot of play on these; that was necessary.
So basically the vertex in quite durable, except for these Ildugur bearings. They have a cool name but don’t live up to their expectations.
Fortunately the build form of these bearings is an industry standard and you can replace them with metal linear ball bearings LM8UU like these: llamatech.be/shop/nl/lagers/ … 15x24.html. The metal ones are all around like a millimeter smaller so printing a ‘filler’ first might be feasible.
Why didn’t Velleman use these in the first place?
