First finished print - Some issues. Any specific advices?
Hi guys,
I tried to print this ( thingiverse.com/thing:732516 ) with the following settings:
  • 3 mm PLA filament
  • 0.3 mm extruder
  • 190° hotend temp
  • 50° mirror bed temp
  • 0.2 mm layers
and I obtained the following:
Generally I’m not completely disappointed, but there are many things that I’d like to solve, in particular:
Uneven layers in the z direction (the surface is “rugged”):
Burnt filament, together with general messy finishing
And last but not least, look at the bottom: it seems that when filling layers, sometimes the extruding material “bursts” and leave a stripe of excessive, melted plastic.
Any advices would be greatly appreciated!
Thanks in advance.
I am not able to see the images you have posted can you please link them in another way and I will try to help.
Hi
It looks like your extruder is a little hotter then 190C
You should check your thermistor for correct positioning.
That might clear up some of the problems.
