So I got the k8204 Z Axis upgrade. I’ve installed it, readjusted the height, and saw that I need to update the firmware. I already had the arduino software installed on my machine (version 1.8.5), I’ve downloaded the
http://www.k8200.eu/downloads/files/downloads/firmware_k8200_v2.1.1.zip
extracted it, and found the folder Marlin - 2560 - LCD. This came to me as a surprise, as I have installed the Z Axis upgrade, but did not install the LCD upgrade. When I tried to compile the code in arduino I got the error:
SdBaseFile.h:38: error: using typedef-name 'fpos_t' after 'struct'
struct fpos_t {
as the type was already defined in stdio.h. I’ve browsed the web a bit and got a hint that I should replace all occurrences of fpos_t in all files in the project to filepos_t. Afterwards I was able to compile the project.
Afterwards I uploaded the sketch using the instructions in http://www.k8200.eu/manual/printing/?c=007
Then I started k8200 repetier, and in the manual control tab, in the gcode line, typed M502 and then M500
Questions
- does the firmware work, if I do not have the LCD update
- if the compilation was the correct one, wouldn’t it make sense to replace the strings for further generations (i.e. releasing a new bundle)?
- should I keep receting the eeprom every time I print?
