The printing goes well, only when I retract the filament, it will not pass out of the cooler (beige plastic cylinder) i.e. it is blocked.
Reason is, the filament is enlarged (too wide, on about 5mm length), probably due to heat.
The coolers are new and the teflon tube inside looks ok to me (23mm length).
I print PLA @ 190°C, flow 78%, retraction 4mm speed 100mm/s
It went OK for many months and I don’t really spot a change that could be the reason. I regularly adjust/fine-tune/experiment the head (dual head).
Any idea ?
Tx !
