Filament guide
Hi Guys,
I noticed now that I almost used a complete 1kg roll that changing the filament could be much imporved/made easier if the filament would be guided sooner after the screw that moves the filament. I was at mid print when I had to reattach the filament because it was broken. When I put it in again I did not knotice that it was not in correctly, but rather stuck in the extruder assembly. The result was the printer went on without me knoticing that no material was extruded.
If the guide would be altered and be closer to the screw (maybe with bigger opening) this cant happen.
What do you think?
best regards,
Christian
