Hello, last time I’ve tried to use the 3D printer, it just stopped to load the filament into the model. I don’t know what’s the origin of the problem. Maybe the filament keeps stuck inside the nozzle, maybe the motor is not working well, … I just don’t know what to do. Any suggestions?
Also check if your nozzle isn’t clogged (happens easily if your temperature is too high (use 190° for PLA and 220° foe ABS). Check the [color=#408040]Wiki [/color]about how to fix a clogged nozzle.
using cura, it’s the software that came with the printer and I know that part of it is fine because i haven’t changed anything, I’m literally trying to print the test model robot that cura already had loaded, I followed the instructions with the printer, setting the software to meet the printers settings and I just printed a robot two days ago without any problems. I just changed the heat to 230 but there is still no change I let it pre heat before putting in the filament but still nothing is coming out of the nozzle. 3d printing mumbai pune delhi india
