Hi everyone,
When I set the printsettings in Cura Repetier on ‘fast’ (default from Velleman), the filament doesn’t ‘glue’ together.
On ‘slow’ it works fantastic
Does somebody know how I can achieve higher printer rates?
Cheers,
Dylan
Hi everyone,
Cheers,
Dylan
You could try to print 0.2mm resolution. Of-course you’ll get less details.
Perhaps a slightly lower fanspeed? is it a large printjob or a smaller?
I was already printing in 0.2mm, it was a printjob of several hours.
cheers,
Dylan
Maybe you could begin slow and then set the speed to 160%
It’s seems that the filament dries to fast before it gets the chance to glue.
Especially with the infill part.
Cheers,
Dylan
[quote=“minitreintje”]It’s seems that the filament dries to fast before it gets the chance to glue.
Cheers,
Dylan[/quote]
Maybe raise the temp a little as it has more time to tack?
While printing try to block for a moment the fan flow with a sheet
of paper and see what it affects.
