Fault detected! Vertex has halted! please power-cycle
I got two out of two errors above on the same general area at layer 2 when printing the same file here and here
Seems to be the accelerometer triggering the tilt kill-switch though no tilt ever happened, head was level all times (seems to be in this video )
Used this gcode file
Will try to clean hotend PCB, sometimes can have too much flux at accelerometer area and cause issues, however if board is faulty, is it possible to purchase a new one?
@pma
There seems to be a problem with Print head PCB.
You can “open a new ticket” here, to receive a replacement printhead PCB.
Velleman Support
