I started assembling the component tester kit, but made the fatal error to solder the lcd display on the wrong side of the pcb. Nothing to desolder it, so I messed this up… Question is if I can order this pcb and display separately. The kit also came with the CD4050 IC. I read about a replacement IC. Maybe it should be better to order it the same way…
