Hi
Ich have a lot other issues which I don’t understand why this happen…
First Issue:
Suddenly, my K8400 cannot reach the needed nozzle temperature anymore.
I changed the Heater-Cardrigde and the Temperatur Sensor with a new one.
When I try to Load Filament, it tries to heat up to 220°C. But it does never reach that temperature anymore. I take a closer look and recognised, that the FAN is blowing and cools down the Heaterblock. When I manually switch of the FAN, it works, the temperature is reaching the triggerpoint and can carry on the process to load filament.
So. what is the quitessence? While heating the Nozzle, it is not necessary to cool it down with a FAN, do you agree with that?
My Solution for the “Load Filament Process” is: Changing the Code in ULTRALCD.CPP, switching the FAN off.
Second Issue…
Also when I start a print, the FAN is always on while heating. I swiched it off in the customizable Start-Sequence. With G-Code M107.
That works so far. But I wonder, was it ment to be?
Third Issue:
Again, related to FAN speed and Heating… While printing, the FAN begins to blow after finish printing the second layer (set in config). Then th temperature falls from 205°C to 180°C and cannot rise again. I do not understand why the Heater-Cardridge is not able to heat it up, even whe the FAN is cooling the Filament. Can you help me?
I already did an autocalibration of PID with M103 as described in another tread.
But its still not working.
I also played around with the configuration of the Filament setting, Section “Cooling”… Even when I set “Max Coolingspeed” to 1%, the FAN does not go lower than 60%. (As I see in the ManualControl Tab) Why is this so?
Uhhh so Sorry, so many question in one post… I hope, you can help me whith this temperature issues…
Thank you in advance
Maexchen
