Hi all,
I’ve been busy with getting my k8200 to work lately. I’ve had it for half a year and it still hadn’t printed anything.
The biggest thing that caused trouble i found out to be the extruder gear (the small one), that was slipping on the extruder motor schaft. Therefore, the extruder didn’t extrude the right amount of material and that caused my prints to be very miserable and full of holes. I tried tightening the screw inside this gear but the screw just ripped off the inside of the gear and couldn’t be tightened anymore. Then i fixed it by supergluing one of the spare gears to the schaft (since, for some reason, velleman decided to not make wired holes in these). That worked fine for about a week, but now the gear started slipping again.
Has anyone else had this problem and designed a good fix for this ?
Thanks in advance
