Extruder stepper not stepping
I have been using my k8400 for about a half year now, but sinds today i have a problem with the extruder stepper, during a print he suddenly stopped.
I have switched the extruder stepper with the y stepper and there he works fine, so its not a broken stepper.
Also i have swapped the stepper driver chips, still every stepper works except the extruder stepper.
Then i checked the main board for faulty components, couldn’t find one. even the 0.9 volts are active on all 4 stepper chips.
The only thing i can find is that when i move the x,y or z stepper there burns a little red light on the main board except at the extruder chip.
Does somebody have any tips on how to fix this?
Is the correct extruder selected in Repetier?
Yes it is, I use old programs witch used before only now the extruded stepper doesn’t work
THe temperature has to be at extruding temperature before the motor will start moving (safety reasons) is this the case?
No it’s not.
If I start a program, it will just heat end start to print but the extruded stepper isn’t working and I checked it if there was a current on the stepper but it isn’t. And the motor is not broken beacaus I can switch it and then he works fine
