Hey,
My extruder motor (or assembly) stops pushing filament.
I checkt already the voltage en it, took it apart and the pulley was at 19,5.
Is there something i have to watch for ?
Axe
Hey,
Axe
It sounds as if the nozzle may be clogged.
Try changing the following settings in Cura configuration.
Filament tab
Hotend end temp 190C
Print tab --> Extrusion tab
Retraction 4mm
Retraction speed 110mm
[quote=“Wrong Way”]It sounds as if the nozzle may be clogged.
Filament tab
Retraction 4mm
Retraction speed 110mm[/quote]
thanks a slot its solved (for now)
Glad to hear it’s working for you.
Happy printing!
