Hi, I’m having problems with the extuder motor by turning it. X,Y&Z axis motors all work perfectly fine so does heaters, bed-plate heater, thermistors etc. I have done the following to check that I have being proceeding correctly but with no luck;
-Checked voltage on driver and set as suggested by build instructions
-Swapped driver
-Removed the extruder motor from everything and left it separate
-Checked the wiring is done ok (which it is)
-Continuity check on soldered wires
-Used dry run
-Left the heater to heat up above or around the set point
At this point I have no idea why the extruder motor is not turning both manually or by print. If you could help me out I will appreciate it.
[quote=“marek”]Hi, I’m having problems with the extuder motor by turning it. X,Y&Z axis motors all work perfectly fine so does heaters, bed-plate heater, thermistors etc. I have done the following to check that I have being proceeding correctly but with no luck;
-Swapped driver
-Used dry run
At this point I have no idea why the extruder motor is not turning both manually or by print. If you could help me out I will appreciate it.[/quote]
Does the motor run when connected to an other axis?
