I was busy printing and the next moment the Extruder motor started to move slowly back and forth. Best to describe it as “twitching” - moving very quickly back and forth.
Other observations:
[list=]No filament is stuck, it does that with and without filament
No gcode problem. I used Cura and Repetier. Sam problem
I did change the tension between the 2 gears
Motor movement is very “lose” while printing. I can actually move it manually in both directions[/list]
Here is the interesting part. I swopped the Z drive on the board with the Extruder. Then it works perfectly. So it is not the Steppermotor
Then I plugged the Z Stepper into the Extruder port… and it work 100%
Swop both back and problem is back…
Anybody else had this?
