No I don’t.
Please note I am using EDU09 software version 1.06 on windows XP running under virtual box hosted by Linux Ubuntu. I have tried also on another PC running under Windows 10 with similar results.
Using EDU09 for experiment 1, I find following value:
[list=]DC Mean=varying between -4.4 and 4.4
Max=18.1V
Min=-21.7
AC Rms=19.7[/list]
Wave is out of border (means that I don’t see top and bottom of the wave on my screen). Strange thing is when I change the volt/div this changes values displayed (example 19.6V with 5V/div is changed as 3.79v when changed to 1V/Div)
For experiment 4:
I have the same issue than described before. No way to see top/bottom of the wave, changing volt/Div doesn’t change the display but changes the values!
In fact as the EDU09 is a kit I mounted myself with a big help from you/your colleagues, I had preferred to test first EDU06 with my other oscilloscope which, as we saw before, doesn’t give the same wave than those expected…
