if i connect the robot to 4 batteries, there is no problem until the batteries get not enough power which i understand.
if i remove the batteries and directly connect the VRBS1 shield over the SK1 to a lab power supply :
- set on 4.5V = the robot can move but it can"t stand on his legs nor stay on them. it seems exhausted.
- set on 6V = the robot doesn’t respect the sketch (the velleman exemple). His legs are stuck in strange position or try to force to move.
Should i use batteries on the VRBS1 shield and connect the VRSSM shield to the power supply ?
