Example code cannot get DHCP address
Hello
the example code is unable to get an ip address from my DHCP.
The UNO does recognize the shield, because if i remove it i get the “Failed to access Ethernet controller” response.
With the shield is on i get:
[quote][Starting the Arduino Server]
MAC: 74:69:69:2D:30:31
Setting up DHCP (this can take a while…)
DHCP failed
IP: 0.0.0.0
Netmask: 0.0.0.0
GW IP: 0.0.0.0
DNS IP: 0.0.0.0
Surf to this IP to view the Arduino Server: 0.0.0.0
[/quote]
Neither light on the ethernetport is flashing, should they?
I tested the cable, and my computer gets a connection on it without a problem.
I’ve assembled the shield myself, so it is entirely possible there is a hardware / soldering fault.
Does anyone have an idea what i could test next?
The reset switch works.
thanks
One thing i could not determine from the documentation:
does it matter witch way round the christal is connected? since there is no indication i figured it did not matter…
Please post some pictures of your print so we can check it visually
cant figure out how to attach a file. lets see if this works
https://drive.google.com/file/d/0B8Rx-tqSR-ECNTYxcUU4eTFJX0k/edit?usp=sharing
https://drive.google.com/file/d/0B8Rx-tqSR-ECZk1ubmpibXIwYzQ/edit?usp=sharing
https://drive.google.com/file/d/0B8Rx-tqSR-ECSTlfMThuZEZhbDg/edit?usp=sharing
https://drive.google.com/file/d/0B8Rx-tqSR-ECTVhBb0lRR01tcjQ/edit?usp=sharing
https://drive.google.com/file/d/0B8Rx-tqSR-ECMjhYRmY5emEzNnc/edit?usp=sharing
https://drive.google.com/file/d/0B8Rx-tqSR-ECV0N5cktRd0JILTA/edit?usp=sharing
https://drive.google.com/file/d/0B8Rx-tqSR-ECYWdfRVJnUW95V2c/edit?usp=sharing
alright that doesnt work,
take 2
https://onedrive.live.com/redir?resid=B742406836B4881C%21151
Do you see any mistakes?
Try to clean the solder connections a bit, also some connections can use some reheating to make sure there is a good contact. I do not see an assembly mistake.
Make sure the arduino uno is plugged in into a powersupply when you try use the shield. Power from usb only is NOT enough.
Ahh, I’ll try that first!
Unfortunately the power was not the (only) problem. Still no dhcp address and no flashing leds on the lan port.
