I have some troubles with the Ethernet VMA04 shield. I use it with a Arduino Mega 2560 R3. I tried several examples from EtherCards and they didn’t work. It is blocked at the ether.begin.
I use Arduino IDE 1.0.6 under Ubuntu 14.10.
Do you have an idea why ?
Thanks !
Is your Arduino IDE version 1.6.0 or 1.0.6?
It is 1.0.6
The Ethernet shield is full compatible with the Arduino Mega, isn’t it ?
I found the solution.
I downloaded the last version of the Ether library and I added the pin 10 as argument of ether.begin :
ether.begin(sizeof Ethernet::buffer, mymac, 10)
That works !
Happy to read you have found a solution.
