Everything works fine when compiling Allbot-Default-Sketches. With the Scratch-Sketch (downloaded from Link within Manual-Page) I get compiling-errors:
[code]C:\Users…\Documents\Arduino\libraries\ALLBOT\ALLBOT_Servo.cpp: In member function ‘ALLBOT_Servo& ALLBOT_Servo::operator=(int)’:
C:\Users…\Documents\Arduino\libraries\ALLBOT\ALLBOT_Servo.cpp:27:1: warning: no return statement in function returning non-void [-Wreturn-type]
^[/code]
[code]C:\Users…\Documents\Arduino\libraries\ALLBOT\SerialALLBOT.cpp:13:11: warning: deleting array ‘((SerialALLBOT*)this)->SerialALLBOT::_callbacks’
delete[] _callbacks;[/code]
[code]In function ‘operator delete []’,
inlined from '__base_dtor ' at C:\Users\...\Documents\Arduino\libraries\ALLBOT\SerialALLBOT.cpp:13:11,
inlined from '__static_initialization_and_destruction_0(int, int) [clone .part.0] [clone .constprop]' at C:\Users\...\Documents\Arduino\exampleSKETCHES\Sketch\VR408Scratch\VR408Scratch.ino:17:14,
inlined from '__static_initialization_and_destruction_0.constprop',
inlined from '_GLOBAL__sub_D_BOT' at C:\Users\...\Documents\Arduino\exampleSKETCHES\Sketch\VR408Scratch\VR408Scratch.ino:699:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\new.cpp:34:12: warning: attempt to free a non-heap object ‘BOT’ [-Wfree-nonheap-object]
free(ptr);
[/code]
I am not familiar with defining classes and libraries but I wonder about the definition-names for serialALLBOT. All Libraries are named with underline, except the serialALLBOT. But in the File serialALLBOT.h the first two lines are this:
#ifndef SERIAL_ALLBOT_H
#define SERIAL_ALLBOT_H
(Environment: Arduino IDE: 1.8.1; WIN7 32bit)
Thank you for help!
JBTW: Manuls are not really consistent…
