Arduino: 1.8.7 (Windows 10), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
In file included from sketch\Marlin.h:23:0,
from sketch\SdVolume.cpp:20:
sketch\pins.h:402:0: warning: “FAN_PIN” redefined
#define FAN_PIN 8
sketch\pins.h:398:0: note: this is the location of the previous definition
#define FAN_PIN 4 // IO pin. Buffer needed
sketch\pins.h:423:0: warning: “HEATER_1_PIN” redefined
#define HEATER_1_PIN 12
sketch\pins.h:417:0: note: this is the location of the previous definition
#define HEATER_1_PIN 9 // EXTRUDER 2 (FAN On Sprinter)
sketch\pins.h:424:0: warning: “HEATER_2_PIN” redefined
#define HEATER_2_PIN 6
sketch\pins.h:419:0: note: this is the location of the previous definition
#define HEATER_2_PIN -1
sketch\pins.h:500:0: warning: “BEEPER” redefined
#define BEEPER -1
sketch\pins.h:475:0: note: this is the location of the previous definition
#define BEEPER 33 // Beeper on AUX-4
sketch\pins.h:502:0: warning: “LCD_PINS_RS” redefined
#define LCD_PINS_RS 27
sketch\pins.h:458:0: note: this is the location of the previous definition
#define LCD_PINS_RS 16
sketch\pins.h:503:0: warning: “LCD_PINS_ENABLE” redefined
#define LCD_PINS_ENABLE 29
sketch\pins.h:459:0: note: this is the location of the previous definition
#define LCD_PINS_ENABLE 17
sketch\pins.h:504:0: warning: “LCD_PINS_D4” redefined
#define LCD_PINS_D4 37
sketch\pins.h:460:0: note: this is the location of the previous definition
#define LCD_PINS_D4 23
sketch\pins.h:505:0: warning: “LCD_PINS_D5” redefined
#define LCD_PINS_D5 35
sketch\pins.h:461:0: note: this is the location of the previous definition
#define LCD_PINS_D5 25
sketch\pins.h:506:0: warning: “LCD_PINS_D6” redefined
#define LCD_PINS_D6 33
sketch\pins.h:462:0: note: this is the location of the previous definition
#define LCD_PINS_D6 27
sketch\pins.h:507:0: warning: “LCD_PINS_D7” redefined
#define LCD_PINS_D7 31
sketch\pins.h:463:0: note: this is the location of the previous definition
#define LCD_PINS_D7 29
sketch\pins.h:510:0: warning: “BTN_EN1” redefined
#define BTN_EN1 16
sketch\pins.h:486:0: note: this is the location of the previous definition
#define BTN_EN1 37
sketch\pins.h:511:0: warning: “BTN_EN2” redefined
#define BTN_EN2 17
sketch\pins.h:487:0: note: this is the location of the previous definition
#define BTN_EN2 35
sketch\pins.h:512:0: warning: “BTN_ENC” redefined
#define BTN_ENC 23 //the click
sketch\pins.h:488:0: note: this is the location of the previous definition
#define BTN_ENC 31 //the click
from sketch\thermistortables.h:4,
from sketch\Configuration.h:554,
from C:\Users\DaeServer\Downloads\Marlin_Futura_A10_Piatto_ON_LCD_ON_MILL_ON (3)\Marlin\Marlin.ino:33:
#define FAN_PIN 8
#define BEEPER -1
#define BTN_EN1 16
#define BTN_EN1 37
#define BTN_EN2 17
#define BTN_EN2 35
from sketch\MarlinSerial.cpp:23:
#define FAN_PIN 8
#define BEEPER -1
#define BTN_EN1 16
#define BTN_EN1 37
#define BTN_EN2 17
#define BTN_EN2 35
from sketch\Marlin_main.cpp:30:
#define FAN_PIN 8
#define BEEPER -1
#define BTN_EN1 16
#define BTN_EN1 37
#define BTN_EN2 17
#define BTN_EN2 35
sketch\Marlin_main.cpp:690:26: warning: extra tokens at end of #ifdef directive
#ifdef SERVO_ENDSTOPS[axis] > -1
sketch\Marlin_main.cpp:718:26: warning: extra tokens at end of #ifdef directive
In file included from sketch\SdFile.h:27:0,
from sketch\cardreader.h:8,
from sketch\Marlin_main.cpp:37:
SdBaseFile.h:38:8: error: using typedef-name ‘fpos_t’ after ‘struct’
struct fpos_t {
In file included from sketch\Marlin.h:10:0,
c:\users\daeserver\downloads\arduino-1.8.7-windows\arduino-1.8.7\hardware\tools\avr\avr\include\stdio.h:950:33: note: ‘fpos_t’ has a previous declaration here
extension typedef long long fpos_t;
from sketch\SdFile.cpp:20:
#define FAN_PIN 8
#define BEEPER -1
#define BTN_EN1 16
#define BTN_EN1 37
#define BTN_EN2 17
#define BTN_EN2 35
from sketch\SdFile.cpp:23:
struct fpos_t {
from sketch\ConfigurationStore.cpp:1:
#define FAN_PIN 8
#define BEEPER -1
#define BTN_EN1 16
#define BTN_EN1 37
#define BTN_EN2 17
#define BTN_EN2 35
from sketch\Sd2Card.cpp:20:
#define FAN_PIN 8
#define BEEPER -1
#define BTN_EN1 16
#define BTN_EN1 37
#define BTN_EN2 17
#define BTN_EN2 35
exit status 1
from sketch\SdBaseFile.cpp:21:
#define FAN_PIN 8
#define BEEPER -1
#define BTN_EN1 16
#define BTN_EN1 37
#define BTN_EN2 17
#define BTN_EN2 35
In file included from sketch\SdBaseFile.cpp:24:0:
struct fpos_t {
sketch\SdBaseFile.cpp: In member function ‘void SdBaseFile::getpos(fpos_t*)’:
SdBaseFile.cpp:298:8: error: request for member ‘position’ in ‘* pos’, which is of non-class type ‘fpos_t {aka long long int}’
pos->position = curPosition_;
SdBaseFile.cpp:299:8: error: request for member ‘cluster’ in ‘* pos’, which is of non-class type ‘fpos_t {aka long long int}’
pos->cluster = curCluster_;
sketch\SdBaseFile.cpp: In member function ‘void SdBaseFile::setpos(fpos_t*)’:
SdBaseFile.cpp:1496:23: error: request for member ‘position’ in ‘* pos’, which is of non-class type ‘fpos_t {aka long long int}’
curPosition_ = pos->position;
SdBaseFile.cpp:1497:22: error: request for member ‘cluster’ in ‘* pos’, which is of non-class type ‘fpos_t {aka long long int}’
curCluster_ = pos->cluster;
from sketch\SdFatUtil.cpp:20:
#define FAN_PIN 8
#define BEEPER -1
#define BTN_EN1 16
#define BTN_EN1 37
#define BTN_EN2 17
#define BTN_EN2 35
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
Can someone help please…
