Hi…
I would like to know… how can i find out, what each error means… e.g. 3FFF, 280A, etc.
Thanks.
Hi…
Thanks.
those are adresses of the memory inside of the pic
if you see those you will probely have a read/write error on adres xxxx
you are getting a write error most likely
Chances are
you don’t have a good serial port or serial cable
You have two pics plugged in at the same time. This doesn’t work
only one pic at a time may be present
